Stuck Dif Cover
  • 2445 Views
Offline timpvjr
Stuck Dif Cover
« on: January 04, 2016, 03:04:07 PM »
Hello!
I'm trying to install a Spartan locker on my front differential.  I have removed the axles, and all the bolts, but I cant seem to get it apart. Any ideas?
Thanks!
Re: Stuck Dif Cover
« Reply #1 on: January 04, 2016, 03:51:33 PM »
What are you trying to remove - the "cover" or the third member - and what vehicle are we discussing?
Offline timpvjr
Re: Stuck Dif Cover
« Reply #2 on: January 04, 2016, 04:06:53 PM »
Its an 86 Samurai.  The front of the dif that houses the pinion.
Re: Stuck Dif Cover
« Reply #3 on: January 04, 2016, 05:23:45 PM »
Presumably you already have the drive shaft removed, put a jack under the nose and jack it up some, it's most likely the sealant that's holding it.
Offline timpvjr
Re: Stuck Dif Cover
« Reply #4 on: January 04, 2016, 05:24:59 PM »
That's a good idea.  Thanks!
