Metro aluminum valve cover on Samurai
  • 19 Replies
  • 14653 Views
0 Members and 18 Guests are viewing this topic.
Offline 02CalTaco
  • 196
« on: February 05, 2012, 08:51:34 PM »
Anyone using the aluminum valve cover from a metro on your 1.3l samurai? Ive seen them on ebay and it sounds like a direct replacement, looks good and i guess they use a better type of gasket. It kinda looks like there is 1 more port than the sami cover has, pcv valve?
Re: Metro aluminum valve cover on Samurai
« Reply #1 on: February 05, 2012, 09:01:03 PM »
Yes you can use the aluminum valve cover. they use a rubber gasket  95-97 swift or metro lsi
Offline 02CalTaco
  • 196
« Reply #2 on: February 05, 2012, 09:13:35 PM »
Do you know if the pcv valve goes in the valve cover on the swift/metro?
« Reply #3 on: February 05, 2012, 09:30:29 PM »
yes it is but you will use your samurai pcv by adapting it to the pcv location on the aluminum cover
Offline 02CalTaco
  • 196
« Reply #4 on: February 05, 2012, 10:05:31 PM »
So, I would just plug the pcv port on my intake manifold? Why can't the swift/metro pcv valve be used instead of adapting the sami one?
Hmm, or no, it would have to be a straight through fitting replacing the pcv at the manifold? Or keep all the stock Sami setup and somehow block of the pcv port on the metro cover. Anyone with pictures of this with a stock intake?
« Last Edit: February 06, 2012, 07:00:41 AM by 02CalTaco »
Offline rbparker
  • 120
« Reply #5 on: February 08, 2012, 07:29:04 PM »
Could I order a swift or metro valve cover rubber gasket from an auto parts store to be used on the oem cover? Reason being, the gasket that auto part stores sell is an incorrect mold.
« Reply #6 on: February 08, 2012, 09:22:02 PM »
you would use the hole in swift v cover to samurai pcv
Offline 02CalTaco
  • 196
« Reply #7 on: February 08, 2012, 09:54:13 PM »
It looks like there are 2 holes in the swift valve cover, only 1 on the Sami cover. So, I guess block 1 off and use 1.
Offline warbird
  • 110
« Reply #8 on: February 09, 2012, 08:58:38 AM »
Alot of folks just put a small aftermarket vent filter on the "extra" port.
« Reply #9 on: February 09, 2012, 12:48:58 PM »
No.
« Reply #10 on: February 09, 2012, 12:51:13 PM »
It depends on what year samurai you have.  If you have an EFI samurai (90-95), then there are 2 hoses that go to the valve cover.....one for the PCV valve and one from the intake air tube.
Offline 02CalTaco
  • 196
« Reply #11 on: February 09, 2012, 07:40:43 PM »
I'm in Cali. so a vent on the extra port won't fly.
86 Samurai, no fi, stock carb and intake.
« Reply #12 on: February 09, 2012, 07:47:39 PM »
Just cap (plug off) the other port then.  No big deal.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #13 on: February 14, 2012, 02:53:55 PM »
Any reccomendations on a particular brand of rubber gasket? I know on my SBC I like Fel Pro but this Zuk is a new animal for me. I just bought a 96 Metro cover like this:
I would also like a recommendation on that rear mini filter if anyone is using 1... What type, what size, where purchased.....
Thanks in advance for the advice guyz!                         Tux...
« Last Edit: February 14, 2012, 02:56:46 PM by tuxblacray »
Offline td57
  • 76
« Reply #14 on: February 14, 2012, 10:52:32 PM »
Tux,
Here's a pic of how I did mine. I will get a better pic when I get home (in a couple of days). I'll see if I have info as to what gasket I used, where I got the filter etc.
Dave
« Last Edit: February 15, 2012, 01:01:41 AM by td57 »
