Motor / trans swap
  • 1708 Views
Offline blaster716
  • 53
Motor / trans swap
« on: July 13, 2010, 07:55:24 PM »
Im planning on swapping my 1.3l in my 92 samuri  for a 8v 1.6 out of a geo tracker is it possible to use the auto trans from the tracker as well ?
Re: Motor / trans swap
« Reply #1 on: July 13, 2010, 08:06:59 PM »
The sami trans tunnel is narrower than the Track/Kick, but if you
want to give the Sami a body lift, it will fit, but then you have an
issue with the t-case and drivelines, not a problem if you have the
skills to do the work
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #2 on: July 13, 2010, 08:38:22 PM »
Yes, you can do it and without a bodylift too if you want but you will need to do some tunnel mods on the side for it to fit.
  • 6573
  • 66
« Reply #3 on: July 14, 2010, 08:21:58 AM »
Trail Tough actually sells some floor pan pieces so you can mod your tunnel and then make it look good afterwards. :)
« Reply #4 on: July 14, 2010, 05:15:38 PM »
Wait, these are supposed to look good when we are done with them?  :D
Offline blaster716
  • 53
« Reply #5 on: July 15, 2010, 06:06:39 PM »
Thanks for all the input , ill check with trailtough
