"CLANK" sound coming from Tcase or driveline??
  • 16 Replies
  • 5436 Views
Offline talonxracer
  • 1284
Re: "CLANK" sound coming from Tcase or driveline??
« Reply #15 on: February 16, 2012, 06:10:58 AM »
I still say it is a combo of excessive clearances with transfer case output needle bearings and slip joint wear being the root cause.
Offline 87Suzi
  • 156
  • Love this little thing!
« Reply #16 on: February 16, 2012, 08:01:19 AM »
I've looked and nothing seems to be loose. If I knew some of the common loose suspension points I could give them a thorough going over. Also, you can see where the bump stops are hitting, maybe this is also caused by the same problem? I understand they are too prevent the body from bouncing all the way down but I haven't bound the suspension up or hit any serious bumps.
