no warm air coming from dash vents...
  • 14 Replies
  • 5168 Views
« on: March 06, 2010, 06:38:38 PM »
I get warm air coming from the floor and the defroster settings, but only cold air coming from the dash vents.  Any ideas?  I have a spare set of heater plumbing just in case.  Thanks.
Offline pllssmith
  • 12
Re: no warm air coming from dash vents...
« Reply #1 on: March 06, 2010, 06:49:41 PM »
if this is on a samurai then look at the slide control and it will show you were the warm air should be coming from. mine shows only defrost and floor like you described.
Paul S.
« Reply #2 on: March 06, 2010, 07:03:54 PM »
It's an 87 JX.  The panel shows a setting for the dash.
Offline cobleeze
  • 29
« Reply #3 on: March 06, 2010, 10:23:49 PM »
But does it show red or blue for the dash setting! Red is heat and blue is cool.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #4 on: March 07, 2010, 06:41:53 AM »
Hey, let's stop guessing here!  It makes you and/or the site look stupid!  If you KNOW the answer to a question, then reply!  Otherwise, keep your guess to yourself!
One of the weird things about the Samurai heating system is that the dash vents are for air conditioning/fresh air only.
They are not connected to the heater's air flow.
I hope that this helps!
« Last Edit: March 07, 2010, 06:45:50 AM by ack »
Ack
« Reply #5 on: March 07, 2010, 08:04:09 AM »
Well - that answers my question - a "fixed itself" moment - love those.  Thanks for the info.
Bobthebiker
« Reply #6 on: March 07, 2010, 09:27:07 AM »
this is interesting info,  I never realized the dash vents were ac only.   makes sense though,  cold air sinks, and warm air rises, so the concept is a good idea.
Offline 10ac
  • 44
« Reply #7 on: March 07, 2010, 10:30:41 AM »
wow... this answers my question as well. ive been trying to figure this out today...lol. thats very weird thats the case tho for it not to be able to blow warm air from the dash vents...hmmmm. o well. thanks yall.
Bobthebiker
« Reply #8 on: March 07, 2010, 11:19:59 AM »
I know what you're sayin.    when I turned the heat on,I swore somthing wasnt right, as the dash vents werent blowing warm air.
Offline zukimoo
  • 330
« Reply #9 on: March 07, 2010, 04:24:17 PM »
it's one of those samurai things...like when people buy one and call me...."how do you open the hood?" I could have made a fortune over the years with the cold air problem.
If you got heat coming out at the defrost then you're one step ahead of most of us.....alot of times the mud/debris falls into the vents on the hood and end up plugging the heater core resulting in no air flow to give heat at the window.
I drove my LJ for 4 weeks before finding the valve to open the coolant flow....I thought the heater was messed up but it was only a closed valve.
06 Baja Buggy
Offline my996duc1
  • 222
« Reply #10 on: March 07, 2010, 08:45:46 PM »
so a person can make sense outa the vent thing but how do we make sense out of the hood release ??  :-\
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Bobthebiker
« Reply #11 on: March 07, 2010, 10:05:47 PM »
THAT one, I'll never understand.  its one of those "what were you thinking?" things to me.   I wouldnt mind relocating it to the drivers side if I can ever figure out how without having to extend things or cut a million new holes.
Online Skyhiranger
« Reply #12 on: March 08, 2010, 11:02:56 AM »
Most samurais are convertibles....read: easy to break into, with a sharp pocket knife.  The glovebox actually has a lock on it, so if someone would break in, then they would still have to get into the locked glovebox (not that it would be too hard) to get the hood open.
Or it is just because it was a convenient place to put the release. :P
That's my theory.
Offline 10ac
  • 44
« Reply #13 on: March 08, 2010, 05:00:53 PM »
when i first got my sammy...took me 10 minuits to find the hood release...lol.
Bobthebiker
« Reply #14 on: March 08, 2010, 08:08:04 PM »
are you kidding? I spent 30 seconds and asked the dude I bought it from because I forgot it was in the glovebox.
I dont think the convertible theory makes any sense though.   if that did, I'd think a lot more convertible vehicles would keep the hood release there too.     I will however buy the belief that it was an effort to make the sammy stand out even more from the jeep and other 4x4 models.
