New to my zuki. Head gasket problems
  • 1896 Views
Offline bubbzzuki
« on: July 12, 2015, 08:39:44 PM »
Hello everyone. Just got my first samurai. 1988 lifted and was told it had low range kit in it. Anyone have any helpful tips for replacing the head gasket on the 1.3? I filled the radiator and it in turn filled #2 cyl with water. I'm hoping the head is not cracked. Won't really know the damage till I get inside.
Re: New to my zuki. Head gasket problems
« Reply #1 on: July 13, 2015, 06:09:03 AM »
How rapidly did it fill ?  The intake manifold has coolant flowing through it, that's actually where I'd start looking - head gaskets & cracked heads have to be pretty bad before you get stuff flowing freely.
Do a compression test - the numbers will be low because the engine will be cold, but, at least you'll have a better idea of what's going to.
Offline bubbzzuki
« Reply #2 on: July 13, 2015, 05:20:42 PM »
Pulled the head off today. The gasket was blown between the two middle cylinders pretty bad. Now I just need to get all the water and oil mixture out of the motor. The cylinder walls look good and no noticeable piston slop like my last jeep motor I tore down.
Sent from my iPhone using Tapatalk
