1 in coil spacer for the front
  • 1997 Views
Offline MAYHEM760
« on: September 06, 2012, 12:23:54 PM »
91 Track 4x4 and it's approx 1 in shorter in the front compated to the rear.  Will a 1 inch lift spacer even it out?
If so, someone please post a pic
Thanks,
Re: 1 in coil spacer for the front
« Reply #1 on: September 06, 2012, 03:03:14 PM »
A 1/2" space will do it or if it is a 2-door pick up some springs from a 4-door Tracker.
« Reply #2 on: September 07, 2012, 07:52:29 AM »
Wouldn't a better approach be to determine WHY the front is low as a first step?
There is a possibility of weak and/or sagging springs at the front and even a lifted rear.  I ask this question as much for my own "education" as to suggest a better approach - the front of one of my small 4WDs (non Suzuki) appears to have a spring problem, and I have been looking at my options with a focus on locating replacement springs.
« Reply #3 on: September 07, 2012, 11:28:45 AM »
Stock the Trackers have a rake to the front end.
Offline jeff1997
  • 1228
  • 27
« Reply #4 on: September 08, 2012, 02:50:58 PM »
I can supply whatever thickness spacers you need. I actually have some short ones laying around that I will send for CHEAP.
3" Masterkit1 body lift
Custom strut spacers
