No fire to spark plugs
  • 1782 Views
« on: March 22, 2010, 01:39:45 PM »
Can anyone help with this problem?? I have just bought a 1990 Suzuki Samurai and cant figure out why I am not getting spark.
I have tried putting in another coil and ignitor module and the relay on the firewall and nothing. Any ideas on what else i could try.    Thanks
Bobthebiker
Re: No fire to spark plugs
« Reply #1 on: March 22, 2010, 02:28:09 PM »
are you sure your plug wires themselves are good?    over time, they do fail you know.
« Reply #2 on: March 22, 2010, 02:47:43 PM »
You just bought it - was it running when you bought it?
Pull the oil filler cap and low down it whilst someone else cranks the engine - is the cam turning?
« Reply #3 on: March 22, 2010, 03:15:29 PM »
I took the dist cap off so I know the rotor is turning so the cam should be turnin, It was running when my friend parked it and then it wouldnt start and no fire when I picked it up. It is a EFI engine it has three wires cumin from the pick up coil. I know you can check a 2 wire but I have no idea how to check a 3 wire.
« Reply #4 on: March 23, 2010, 11:27:57 AM »
Could be the ECM.  They are known to go bad in the samurais (90-95).
