no spark
  • 1748 Views
Offline Wilnailu
  • 12
no spark
« on: October 11, 2012, 04:43:34 PM »
1993 sidekick, I installed a good used engine complete,tried to start it will not start, checked with coil wire handheld to coil tower it will spark one time only.It has good fuel pressure,I already tried diff coil and dist,same crap,HELP
Offline airdale navy
  • 82
Re: no spark
« Reply #1 on: October 11, 2012, 05:36:19 PM »
WHAT YEAR WAS THE ENGINE YOU INSTALLED?
91 sidekick,8v,sky 1.5 lift,235 tires,full synthetic oils !GM alternator upgrade.Ford Mustang coil.4DR front brakes.
Offline Wilnailu
  • 12
Re: no spark
« Reply #2 on: October 11, 2012, 10:51:34 PM »
It is a 1994 1.6l 16v.I used all of the cars wiring harness except the injector section.The white plug back.
Re: no spark
« Reply #3 on: October 12, 2012, 03:42:02 PM »
Unless you fried the ECM it sounds like a grounding issue.  Check the distributor ground first them go from there.
Offline Wilnailu
  • 12
Re: no spark
« Reply #4 on: October 19, 2012, 11:31:35 PM »
after man hours a friend stopped by and in about 5 mins. found a broken wire going to the dist.Fixed it and it started and ran perfect.Thanks everybody
