O-2 sensor
  • 23 Replies
  • 5793 Views
Offline jow003
  • 403
O-2 sensor
« on: June 15, 2010, 01:03:47 PM »
What are the symptoms of a bad o2 sensor?
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Bobthebiker
Re: O-2 sensor
« Reply #1 on: June 15, 2010, 01:17:28 PM »
usually a check engine light,  the vehicle may run poorly, or get poor fuel economy,   theres a lot of symptoms from what I remember about this.
Re: O-2 sensor
« Reply #2 on: June 15, 2010, 03:14:01 PM »
My 96 got great mileage at around 40 mph, pretty lousy otherwise.  And you could tell it was running rich most of the time, you could smell it in the exhaust.
« Last Edit: June 18, 2010, 09:28:01 AM by Drone637 »
Offline jow003
  • 403
Re: O-2 sensor
« Reply #3 on: June 18, 2010, 07:00:30 AM »
|removethispart|@ bob, my cluster is out of service, only thing that works on it is the bliker lights and the battery light which is on when ever power os going to it
|removethispart|@Drone, it seems like its running rich, i moved from ~70ft elevation to 6600.  would the ECM and O2 sensor regulate that normally on a 87?
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Bobthebiker
Re: O-2 sensor
« Reply #4 on: June 18, 2010, 07:13:27 AM »
I just remembered, there is a certain voltage range within which the O2 sensor should be.  I dont know what range it is, but basically its easy to test with a multimeter.
Re: O-2 sensor
« Reply #5 on: June 18, 2010, 09:29:17 AM »
The ECM should adjust but it will take a while.  Do you have an 87 Samurai?  If so that is carburated, not ECM controlled.
Offline jow003
  • 403
Re: O-2 sensor
« Reply #6 on: June 18, 2010, 10:51:19 AM »
haha i keep getting different answers from ppl. yes its a 87 and carb'd.  if i change out the o2 sensor, what else will i need to do?
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: O-2 sensor
« Reply #7 on: June 18, 2010, 04:12:26 PM »
Carb's don't use an 02 sensor, I thought you were talking about a Sidekick.  You probably just need to tune it for the higher altitude.
Re: O-2 sensor
« Reply #8 on: June 18, 2010, 04:25:12 PM »
If I'm not mistaken the 87 Samurai has a "feedback carburetor" which does use an O2 sensor and a very primitive ECU - since this is not fuel injected, there are no injectors and the ECU pulses a mixture control solenoid valve that adjusts the mixture based on feedback from the O2 sensor - unfortunately I have no idea how altitude affects this setup.
Offline jow003
  • 403
Re: O-2 sensor
« Reply #9 on: June 18, 2010, 08:38:02 PM »
do you know a place that would?  i have been told that a MY-Side setup is the way to go but if i can make it work with what i have id rather save the money
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: O-2 sensor
« Reply #10 on: June 21, 2010, 01:04:03 AM »
You might be right, looking at the wiring diagram there is a spot for an 02 sensor.  I must have overlooked it when I was checking out the wiring diagram earlier.
Offline jow003
  • 403
Re: O-2 sensor
« Reply #11 on: June 21, 2010, 11:44:15 AM »
-Drone, how do i go about tuning it? and what diagram were you looking at?
-Fordem, how would i check to see if the sensor is bad or if that is my setup?
thank you all for the help
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline jow003
  • 403
Re: O-2 sensor
« Reply #12 on: June 22, 2010, 09:35:05 AM »
so... did sommore research and found that carb'd samurais have a High Altitude Controller (HAC) its supposed to be switched one way if you are below 4K feet in elevation and switched the other if you are above.  only problem is the chilton book i have is a POS, go figure and doesnt really do a great job of explaining if its good or bad.  i think this is it tho, correct me if im wrong.
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: O-2 sensor
« Reply #13 on: June 22, 2010, 11:16:42 AM »
jow003:  I pulled the info from Acks Faq wiring diagram at http://www.acksfaq.com/ewd_86-89_g13_carb.htm
You might try reading up on the Factory Service Manual.  You can find one over at http://www.suzukiinfo.com/
Re: O-2 sensor
« Reply #14 on: June 22, 2010, 12:19:01 PM »
It is from .2 to .8 volts (notice the decimal in front of the numbers).
Umm, all samurais had an O2 sensor.
