O2 sensor
  • 1739 Views
Offline dwain
O2 sensor
« on: February 06, 2016, 09:00:36 PM »
 This is my first post, and I am sure it will not be my last. I recently purchased an 87 Samurai Tin Top. It has a weber  carb. on the stock engine. The O2 sensor wire has been cut  about 2 inches from where it screws into the header. The sensor light is on all the time on the dash. I have not tried to reset the switch yet. Do I need to get a new sensor to put in, or can I splice the wire? The one half of the fuse link connector which would have been on the end of the sensor wire is gone. What would you recommend?
Re: O2 sensor
« Reply #1 on: February 07, 2016, 05:01:55 AM »
If you're running a Weber carb, the O2 sensor is no longer used.
The original Hitachi carb was an electronic feedback carb and used the O2 sensor and a very primitive ECU to adjust the air/fuel mixture, the Weber is a conventional carb with no electronics.
Offline dwain
Re: O2 sensor
« Reply #2 on: February 07, 2016, 01:54:08 PM »
Great. That is what I like to hear. That is one less problem I will have to deal with. Thanks for the info.
