Please help! Alternator plug missing.
  • 1848 Views
« on: November 06, 2011, 08:50:45 PM »
Alright so my buddy got a smoking deal on an 87 Samurai but it needs a little TLC. The plug that goes into the voltage regulator on the back of the alternator seems to be missing from the harness. I don't know why someone would cut that off but I went over it pretty well and could not find it anywhere. I was curious if you guys knew what colors the wires were going into that plug? All the schematics I found didn't tell me wire colors. I'm hoping I can find the cut wires in the harness and go cut a plug off at a pick n pull yard or something. Any help is greatly appreciated as we can't keep the battery charged without it! Thanks in advance!
Offline mrfuelish
  • 2862
Re: Please help! Alternator plug missing.
« Reply #1 on: November 06, 2011, 09:08:41 PM »
good chance if you cut the plug off from the yard you will see where they go and the pretty colors.
Offline talonxracer
  • 1284
« Reply #2 on: November 07, 2011, 06:31:46 AM »
There are two wires for that connector, the black w/white stripe is the excitation voltage and the white wire is for the charging lamp on the gauge cluster.
It could be the PO was intending to upgrade to a GM 12Si alternator.
« Reply #3 on: November 07, 2011, 06:53:35 PM »
The alternator plug is a big round green plug.  Kinda hard to miss.
