pluged oil hole in con rod
  • 1867 Views
Offline stovokor
  • 27
« on: May 09, 2012, 08:25:08 PM »
any one know the best way to clean out the oil hole in the conecting rods i spun a bearing and the oil hole is now pluged with what was my bearing
Re: pluged oil hole in con rod
« Reply #1 on: May 10, 2012, 07:24:07 AM »
Isn't it a straight hole?  I'm thinking a hole that oil from the journal sprays through to lube the cylinder walls - run a wire through it.
« Reply #2 on: May 10, 2012, 03:54:45 PM »
I agree with fordem, push a solid thick wire through it, but if it has that much junk in it you may want to CLEAN everything in that bottom end. The crank oil holes are drilled ( bored?) at an angle so they don't go straight through, but angle out or in.
Offline talonxracer
  • 1284
« Reply #3 on: May 10, 2012, 05:04:41 PM »
If the bearings spun enough to deposit material within the oil feed holes I would suspect the rods will need to be recond or new bearings will not fit precisely and end up spinning again.
Offline stovokor
  • 27
« Reply #4 on: May 11, 2012, 06:56:25 AM »
thanks for the tips i was trying to see if i could get away with just changing the one bearing but no dice con rod is good but the crank need turning so i will pull the motor and rebuild it   thanks for the help
