Rapid RPM Drop When Stopping???
  • 4715 Views
Offline zacparry
  • 53
« on: August 04, 2010, 03:53:25 PM »
I bought an 88 Samurai this last weekend and it runs and drives great but when I am slowing to stop and I put in the clutch the RPMs drop rapidly to about 500 and the engine will almost die, recovering to the 800 RPM idle.  It does idle a little rough and the engine has 50k on it while the rest of the car has 150k on it.  I have not tinkered with the carb settings yet and would like to know what you guys think.  I plan on doing the cursory new owner tune-up - plugs, wires, cap, and rotor this weekend.
Offline sirmasterj
  • 8
Re: Rapid RPM Drop When Stopping???
« Reply #1 on: August 11, 2010, 11:24:31 PM »
You know I have this same problem with my 99 tracker.  Mine is an automatic with a 2.0l  If you get an answer to your problem, could you pass it on to me.  When I slow to a stop, my idle drops to about 2-300 rpm and sits at that idle for about 10 secs then it rebounds back to the normal 8-900 range.  It makes the whole vehicle shake like crazy.  Please let me know if you get an answer on this.
Offline zacparry
  • 53
« Reply #2 on: August 12, 2010, 06:43:48 AM »
I don't know about your Tracker because it should have EFI.  Is your computer throwing any codes?  Does it start ok?  I had a camshaft position sensor go bad in another vehicle and it would idle like crap.  Otherwise it could be a bad throttle position or maybe some other sensor that I don't know about on that vehicle.
You may try to run a can of seafoam or Lucas injector cleaner though it just to see if that helps, but I would definitly check into it more to see if there is a more serious problem.
  • 6589
« Reply #3 on: August 12, 2010, 07:40:55 AM »
Your problem is most likely different then the original post in this thread but both could try this as it may help the Samurai too. But on your Tracker, I bet ya that your EGR valve is gummed up and is sticking. They are quite easy to take off and clean out with some compressed air and a little brake cleaner.
Hopefully, that helps.
Offline toofaroffroad
  • 226
« Reply #4 on: August 21, 2010, 05:14:50 PM »
Hi guys, I had this exact same problem. I got really good at holding the e-brake and keeping my foot on the gas at red lights. I finally got a new battery. my battery was old shitty and not holding a charge. Since I put the new battery in I have not had that problem. I'm not saying that putting as new battery in will fix your problem. Just telling you what happened with me. Good luck.
Offline eschneider
  • 40
« Reply #5 on: August 21, 2010, 05:38:44 PM »
If it only happens when you step on the brake.....
Vacuum leak through the brake booster?
Offline ft6crt
  • 10
    • The Abyss
« Reply #6 on: August 22, 2010, 10:19:55 PM »
Yeah.. what he said...
