What's you thought on heating problem?
  • 1420 Views
Offline sidekickyc
  • 137
« on: June 20, 2017, 03:42:06 PM »
Hi, I've not looked at this sidekick yet ~wanted to hear your thoughts first. What do you think it could be?
Mechanics special. 01' grand vitara, 2.5L V6, 4x4, automatic. 198xxx miles. Runs great besides a random over heating issue. Passes smog. A lil rough on the outside. Been a great vehicle, just tired of trying to chase the problem. I've replaced radiator, water pump, thermostat and still over heats sometimes. Come take a look. Asking $650.00.
Re: What's you thought on heating problem?
« Reply #1 on: June 21, 2017, 06:37:37 AM »
I have a 2.7L with a 5 speed automatic, and have experienced random overheating issues.  As my drivetrain is squeezed into a 93 2 door, there is a big difference between vehicles, but my solution has been an oil cooler for the transmission, and a good 3000 cu.ft. fan replacing the auxiliary fan.  I route the transmission oil through the oil cooler, then the radiator and back together transmission.  That way I am not over cooling the transmission, but still taking a load off the radiator.  As that wasn't sufficient when crawling, I replaced the auxiliary fan (in my case the only fan) with a 3000 cu.ft. fan.  Haven't had problems with overheating since.
The solution may be as simple as replacing the fan clutch, or a good tune up.
Enjoy your new project.
Offline sidekickyc
  • 137
« Reply #2 on: June 21, 2017, 10:56:01 PM »
BRD HNTR, Thanks for coming back.  I may take a look at this with a buying eye.
If I pick the one up I'll let you know~
Richard
Offline sidekickyc
  • 137
« Reply #3 on: June 24, 2017, 02:58:04 PM »
Well, this car was just driving out when I contacted the owner~I wasn't meant to get it.
