Just curious... how many leaves will be remaining in the spring pack once you remove the add a leaf? (both front and rear) Your front kinda looks like 3. and... I didn't go back to look at the rear in the video.I'm thinking you will want to add some stock leaves to both packs depending on what you have left. I can't tell you for a Spoa set up what is optimum but I am sure someone else will have some insight.I would like to know how much lift the add a leaves gave you as well. Tux...
"I might be interested in your add a leaves if the would arch the current spring pack up a minimum of 2".... "
