replacing my 3 speed transmission
  • 1952 Views
Offline ColtonP
  • 147
« on: May 14, 2010, 07:34:09 AM »
i have a 1995 geo tracker lsi my transmission has always acted up im just getting sick of it. when its cold it will not shift from first until it has run in gear at about 4500rpm for 90 secs i was wondering how hard it is to swap my transmission out for a used one i have changed fluid twice and i used lucas on the second change no help there. i also wanted to know how complicated the pocess is and if it could be changed to a 5 speed manual or a for speed automatic with out much trouble. Please  help me
THANKS AHEAD OF TIME :)
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
Re: replacing my 3 speed transmission
« Reply #1 on: May 14, 2010, 08:29:45 AM »
Could it just be a bad shifter sheet/bushing? That is a cheap, easy thing to try b4 spending the big bucks! And can do it yourself in less than an hour.
Online Skyhiranger
« Reply #2 on: May 14, 2010, 05:56:58 PM »
I think he has an auto tranny, so the shifter sheet will do him no good, since those are for manual trannys.
knights09....your best choice is to replace it with another 3 speed.  A 5 speed manual is doable, but you have to add the clutch pedal, flywheel, clutch, clutch cable, etc.  The 4 speed would be pretty difficult, since you need to replace the ECM and most of the wiring harness, since 4 speed autos are computer controlled.
I had a 3 speed that was acting similiar to how yours is.  I flushed the tranny with new fluid, changed the fluid and filter and it started shifting.  The more I ran it, the better it shifted....finally got it working correctly again.
« Last Edit: May 14, 2010, 05:58:44 PM by Skyhiranger »
