Rough idle when in drive.
hwally
22
June 02, 2023, 08:04:53 PM »
I just bought a 99 sidekick and it has a very rough idle when in drive (it's an automatic). If I apply the gas pedal and raise the rpms to 1000 rpms or above it smooths out. If I put it into neutral it also smooths out. When it is idling rough the idle fluctuates 2 or 3 hundred rpms. I'm wondering if it isn't a vacuum
leak. Years ago I had another sidekick and I remember having the same problem but I don't remember how I solved it. I'm wondering if it isn't a common problem. Thank you for any help you can send my way.. Where is the diagnostic port located. I live in rural Mexico so resources are limited. There is an Auto Zone an hour away.
fordem
4333
170
Re: Rough idle when in drive.
June 03, 2023, 04:34:48 AM »
The Sidekick's last year of production was 1998, so you need to let us know what it is you're driving - assuming a late 90's Sidekick, the diagnostic port should be under the driver's side dash alongside the transmission tunnel.
