Running Poor
  • 16 Replies
  • 4479 Views
0 Members and 40 Guests are viewing this topic.
Offline Sundance58301
  • 79
    • Dry Lake Farm
Running Poor
« on: November 25, 2011, 08:52:55 AM »
My 93' Kick with 1.6 has always idled fast. But now a new
issue.
Just lately after warming up it idles slow (200 rpm) and is
erratic. Like it's going to die.
The MPG has dropped markedly too.
It seems to run fine at highway speeds but I get 22 mpg where
I used to get 30 mpg regularly.
Where to look first?
1992 Suzuki Sidekick JX
*4 Door
*5 Spd
*16V
Re: Running Poor
« Reply #1 on: November 26, 2011, 07:09:53 PM »
I would check for any codes, if none are present, check the sensors with a multimeter. If they check out fine I'd suspect the ECM.
Proud owner of a low mile 1992 Tracker 4x4 rust bucket.
Re: Running Poor
« Reply #2 on: November 27, 2011, 05:48:44 AM »
Check the EGR for clogging as well as the cat for clogging too.
  • 79
    • Dry Lake Farm
Re: Running Poor
« Reply #3 on: November 27, 2011, 02:31:56 PM »
Started it this morning and it went to the usual 2000+
RPM for 30 seconds or so and then dogged down and almost
died.
Then it will smooth out and run OK for a bit and dog. This
repeats.
If it was a clogged converter wouldn't it run like crap all the
time?
I only have an OBD2 reader for codes.
*4 Door
*5 Spd
*16V
Re: Running Poor
« Reply #4 on: November 27, 2011, 07:54:21 PM »
You don't need a code reader for a 93 (it is OBD1).  You just short the "B" and "C" pins in the 4 wire plug up by the battery and then turn the key to run and watch the CEL and count the flashes to determine the code(s).
If you haven't done a tune up (new plugs, wires, cap, rotor, air filter, adjust valves) lately, I would do it.  Might also be a good idea to replace the fuel filter.
The EGR passages and EGR valve are bad about clogging up on these engines.  So a thorough EGR system cleaning may be a good idea too.
You could also check/replace all the small vacuum lines too.  A leaking vacuum line will cause an unstable idle.
The ECMs are known for going bad in these.  I had one that would do something very similar to what you describe.  It would run fine for awhile (or at idle), but would then bog out so bad that I would hardly be driveable (actually, I couldn't get much above about 25mph).  The ECM was bad.  Some can be fixed, some can't.
  • 79
    • Dry Lake Farm
Re: Running Poor
« Reply #5 on: November 28, 2011, 06:21:59 AM »
Thanks I will do this this morning. I assume this will clear the check engine
light?
I just bought it 5K ago and he had done most of this. But I'll give
them a good check, especially the dist cap.
I am out of town without my manual. I assume the EGR valve is a
replacement issue? How do you clean the passages?
I checked them all, but it is cheap enough to replace them
all. I'll pick the line up today. I have to travel back home Wednesday
morning (400+ miles).
I am guessing that you replace the ECM after the above it it doesn't
cure it? Are there test for the ECM?
Thanks to everyone who responded. And thanks for a great forum
*4 Door
*5 Spd
*16V
Re: Running Poor
« Reply #6 on: November 28, 2011, 06:34:00 AM »
No.  Shorting the pins in the plug by the battery just allows you to read what codes are stored.  The only way to clear them is to either fix the problem, or unhook the battery for awhile.  If you unhook the battery, but don't fix whatever caused the code, the code will come back (the CEL will light up again).
I have seen worn (improperly gapped) plugs and bad plug wires cause more running issues than a bad cap or rotor.
To clean the EGR valve and valve passages, I use a stiff wire, brake cleaner and compressed air.  You can use a small flat screwdriver on the EGR valve.  Just be careful and don't gouge the shaft inside the EGR valve.  You can also use a small drill bit, to clean out the EGR valve passage that the large rubber hose hooks to.
The best/easiest test for a bad ECM is to swap in a known good one.  Most bad ECMs can be fixed by replacing the capacitors and fixing any bad copper traces.  But some can't be fixed (the ECM is damaged beyond repair, the bad components/traces can't be found, etc.) and have to be replaced.
  • 79
    • Dry Lake Farm
Re: Running Poor
« Reply #7 on: November 29, 2011, 05:37:01 AM »
Does anyone have a picture of the EGR valve and it's placement
on the 1.6? I am several hundred miles from home without my
manual (it will come with me in the future).
When the Kick is idling low it has a sickeningly sweet, rich smell.
Like it's getting too much fuel.
*4 Door
*5 Spd
*16V
Re: Running Poor
« Reply #8 on: November 29, 2011, 05:40:35 AM »
No pic, but it is on the passengers side rear of the engine.
  • 79
    • Dry Lake Farm
Re: Running Poor
« Reply #9 on: December 01, 2011, 04:31:54 PM »
I made it home OK.... And now I can slide it into the shop
to work on the EGR.
Got as low as 18 MPG coming home. I had a light trailer on
but it always got 25 to 28 mpg with the trailer.
Hope it's the EGR
*4 Door
*5 Spd
*16V
  • 79
    • Dry Lake Farm
Re: Running Poor
« Reply #10 on: December 01, 2011, 04:33:21 PM »
Oh and I ran a bottle of Seafoam through it as well as a quart
of Marvel Mystery oil (not together) and they didn't help the
issue at all.
*4 Door
*5 Spd
*16V
Offline ebattleon
Re: Running Poor
« Reply #11 on: December 01, 2011, 05:02:58 PM »
What error code did you get from the ECM?
Common Sense Absent
Offline ranger88den
  • 279
  • 12
  • 79
    • Dry Lake Farm
Re: Running Poor
« Reply #13 on: December 02, 2011, 08:58:31 AM »
Anyone sell rehabed ECU's?? Beyond what I can do as far
as replacing capacitors etc.......
*4 Door
*5 Spd
*16V
  • 79
    • Dry Lake Farm
Re: Running Poor
« Reply #14 on: December 08, 2011, 07:37:45 AM »
Have you been driving my Kick without me knowing??
I'd appreciate it if you fix my problem with it after driving
it.
*4 Door
*5 Spd
*16V
