Sammy fuel problem wont start please please help
  • 33 Replies
  • 5788 Views
Re: Sammy fuel problem wont start please please help
« Reply #30 on: November 21, 2011, 03:58:18 PM »
I believe you. Instead of installing the old tank I'm going to go get 5 feet of rubber fuel line. Attach it to the fuel pump and run the other end of the hose in a 5 gallon gas can rt in front of me. Beg the fiancee to turn the engine over so I can observe if its pumping at a reasonable rate and see how much is entering the carb.
I had originally asked about the fuel filter being drained and slowly filling back up over a minute or so while  not cranking the engine.
Once the fuel system is primed the filter should never be dry of fuel correct?
Offline mrfuelish
  • 2862
« Reply #31 on: November 21, 2011, 04:59:27 PM »
correct, that is why they have a check Valve between the gas tank and the fuel filter If I remember correctly. but one should be there.
« Reply #32 on: November 21, 2011, 05:43:49 PM »
OK Ill get the hose tomorrow to narrow down some of the variables. I'll be sure to comment back with what i find and any additional questions.
Thanks again
Offline ebattleon
« Reply #33 on: November 24, 2011, 03:21:05 PM »
You may have an air leak some where between the tank and the pump, which would give an air lock.
Common Sense Absent
