Sammy fuel problem wont start please please help
  • 33 Replies
  • 5796 Views
Re: Sammy fuel problem wont start please please help
« Reply #15 on: November 21, 2011, 01:51:28 PM »
Thanks for all the replies too. Im trying to respond as fast as possible so I dont waste ur time or expertise.
Offline mrfuelish
  • 2862
« Reply #16 on: November 21, 2011, 01:52:36 PM »
if your not worried about smog then no you do not need it, just unhook the hose that goes back to the tank from it, do you still have the check valve in line back by the fuel filter?
« Reply #17 on: November 21, 2011, 01:54:34 PM »
No smog concerns here. 100% trail rig. I dint see any type of valve. Just a fuel filter I installed. Does that line need plugged for vacuum purpose?
« Last Edit: November 21, 2011, 01:56:24 PM by RampedRaptor »
Offline mrfuelish
  • 2862
« Reply #18 on: November 21, 2011, 01:56:43 PM »
OK there should be a small valve in line next to the filter that air might have damaged, I would drop the tank first and clean it out, there is no screen inside the tank, anything in there will plug the line.
« Reply #19 on: November 21, 2011, 02:00:20 PM »
Previous owner must of got rid of valve. I'll drop tank tonight and clean out. Is there a main cover I pull "like on the trackers" to gain access to the inside of the tank?
Offline mrfuelish
  • 2862
« Reply #20 on: November 21, 2011, 02:04:56 PM »
there is a round sending unit on top wit about six screws just pull it out and look at the pick up tube to make sure it is not rusted out or blocked, I add more hose on top of the tank for the return line to make it easy for me to get back in by myself, you night have to get help going back in.
« Reply #21 on: November 21, 2011, 02:07:58 PM »
Will see what I can do and Ill get back to you later tonight Back to replacing the mechanical fuel pump. Its held in by two bolts right? Once I pull the bolts with it slide straight out then install the same way?
thanks for the help
Offline mrfuelish
  • 2862
« Reply #22 on: November 21, 2011, 02:13:00 PM »
the pump could be good, run a line from the input to a gas can and try it.
Offline mrfuelish
  • 2862
« Reply #23 on: November 21, 2011, 02:19:48 PM »
it has been awhile but yes easy, you might have to bump the engine a little to make it easy er to go back in.
« Reply #24 on: November 21, 2011, 02:20:32 PM »
It does spray some but without a gauge I'm not sure what is adequate.
Offline mrfuelish
  • 2862
« Reply #25 on: November 21, 2011, 02:22:38 PM »
It might be enough, I would look at the tank if it had a rag in it. but process of elimination works good too.
« Reply #26 on: November 21, 2011, 02:25:10 PM »
Heading out know to do tank. Thanks again for ur time all your help. Ill update once I get the tank removed and cleaned out.
Offline mrfuelish
  • 2862
« Reply #27 on: November 21, 2011, 02:27:26 PM »
10-4
« Reply #28 on: November 21, 2011, 03:32:51 PM »
Removed tank and cleaned inside out. Little rust flakes but nothing that looks like it would clog the hoses. "much cleaner then I expected on the inside"  I poured gas down tube to make sure no debris was in it. I can hook it back up now but i dint expect a change
Offline mrfuelish
  • 2862
« Reply #29 on: November 21, 2011, 03:48:18 PM »
ya but you have to know these things look like Tonka trucks to little kids and You would not believe the toys I have Found in some of the tanks.
