Tranny noise
  • 2408 Views
Offline Sundance58301
  • 79
    • Dry Lake Farm
Tranny noise
« on: May 17, 2012, 04:41:57 PM »
My '93 Sidekick 5 spd has developed noise in all gears except
4th. Shifts OK. noise is not grinding but almost bearing like.
Any ideas??
And why is 4th quiet?
1992 Suzuki Sidekick JX
*4 Door
*5 Spd
*16V
Re: Tranny noise
« Reply #1 on: May 17, 2012, 09:45:33 PM »
Just finished rebuilding a noisy transmission.  The gears and syncro's were fine, two bearings just had the race's, it got quiet when that happened (it had been noisy for a long time).  We DIDN'T get our rebuild kit from one of ZW vendors, & I was not impressed with that kit.  No instructions or even same bearings.  Get your kit from ZW vendor.  Take photo's of open case to refresh memory.  It is not difficult.
Installing Transmission this weekend.
Re: Tranny noise
« Reply #2 on: May 18, 2012, 10:17:57 AM »
Give us a call at LOW RANGE OFF ROAD we will be happy to helb you with your Transmission problem 888-726-8724
Re: Tranny noise
« Reply #3 on: May 18, 2012, 10:47:12 AM »
Any ideas??
It sounds bearing like because it is a bearing noise, probably the input shaft bearing, 4th is quiet because it's a direct drive (1:1) and the input & output shafts are coupled together, so that the input shaft is supported at both ends.
Time for a rebuild.
  • 79
    • Dry Lake Farm
Re: Tranny noise
« Reply #4 on: May 18, 2012, 12:59:50 PM »
A rebuild is beyond my time right now...... The beast is
going on Craigs List tonight..... thanks though
*4 Door
*5 Spd
*16V
