Question on egr bypass valve - I think that's what it is
  • 1746 Views
Offline RJkick
  • 634
« on: October 01, 2012, 04:49:52 PM »
Can someone verify if this part is broken and if so where I can get another.  I'm not sure what it is called but it looks like the top is broken off of it. The part on the left with no hose in the top of it.  Thanks
« Last Edit: October 02, 2012, 07:24:07 AM by rjkick »
Offline RJkick
  • 634
Re: Question on egr bypass valve - I think that's what it is
« Reply #1 on: October 02, 2012, 09:26:34 AM »
Does anyone have a 92 4dr sidekick they can check for me to see if it is broken
« Reply #2 on: October 02, 2012, 03:51:24 PM »
Looks exactly like mine, but still can't tell if it's broken without a closeup.
Offline fuzzy1
  • 350
« Reply #3 on: October 02, 2012, 04:17:48 PM »
Yeah, that's the EGR VSV valve... & yeah it's broken. It should have an oval cylinder on top like this:
Iirc in reading, the cylinder is meant to smooth the pulses from the intake air. I've also read of ppl running them like that & having no problems... but that seems like it would create a vacuum leak to me...? You could prolly get a used one at a junkyard or Trail Tough.
Hth,
Fuzz
Non Illegitimi Conterat
« Reply #4 on: October 07, 2012, 08:11:48 AM »
I thought it was just a cover over the breather hole.
Offline RJkick
  • 634
« Reply #5 on: October 09, 2012, 11:57:25 AM »
Found another at the local pick a part and was told it was a filter\breather type part
Oh well - at least it looks like the fsm now
thanks
