Part name or number
Part name or number
rodmax
4
Part name or number
February 02, 2011, 04:23:47 AM »
I need to find the name and or number of the pipe that goes into the back of the water pump that the coolant hoses connect to. I have a leak and need a replacement. Thanks.
Suzuki Sidekick 1997,1.6l.
fordem
4334
170
Re: Part name or number
February 02, 2011, 04:59:04 AM »
Pipe. water inlet - 17550-58B00
rodmax
4
February 02, 2011, 07:43:29 AM »
Skyhiranger
3734
122
I don't buy, what I can build
Reply #3 on:
February 02, 2011, 02:35:29 PM »
There is an oring on that, where it goes into the backside of the water pump area. So unless you know for sure it is the pipe leaking, I'd check the oring first.
