sj410 oil pan bolt hole stripped
  • 2518 Views
Offline ontario410
  • 30
« on: September 28, 2023, 04:45:55 PM »
 i changed my oil pan gasket at the beginning of summer and still had a bit of a leak so i got under and re torqued the oil pan bolts to 8 foot pounds which i found on a chart online. all of the bolts retorqued fine however one of the bolts where the engine mates the transmission behind the small sheetmetal cover is not torqing up and i believe is stripped. has anyone had this problem? im assuming i will need to put a helicoil in? or is there another way to repair?
 thanks
Re: sj410 oil pan bolt hole stripped
« Reply #1 on: September 29, 2023, 05:06:41 PM »
A helicoil is what I would consider an easy repair - and by the way, Suzuki doesn't use oil pan gaskets, just RTV sealant.
  • 6594
  • 68
« Reply #2 on: October 29, 2023, 04:49:13 PM »
This is a good idea.
Offline ontario410
  • 30
« Reply #3 on: July 20, 2025, 05:32:29 PM »
I ordered a cork pan gasket directly from megazip a OEM part
