Distributor???? QUICK
  • 2884 Views
Offline Taymer
  • 18
« on: March 06, 2010, 10:02:59 AM »
Im doing an engine swap because the old one was just getting old but anyways when i put the distributor in where are the points suppossed to be?
Offline warbird
  • 110
Re: Distributor???? QUICK
« Reply #1 on: March 06, 2010, 12:58:09 PM »
probably not if it wasn't marked...
Offline zukimoo
  • 330
« Reply #2 on: March 06, 2010, 02:22:59 PM »
check the book if you got one. TDC of piston #? and the rotor should point to that piston. I can't remember if it's #4 or #1 but someone will probably post.
06 Baja Buggy
Offline Taymer
  • 18
« Reply #3 on: March 09, 2010, 05:59:15 PM »
I figured it out by myself but its (1-3-4-2) and the roter spins counter clockwise.
Offline warbird
  • 110
« Reply #4 on: March 10, 2010, 04:47:48 PM »
10-4! 8)
Online Skyhiranger
« Reply #5 on: March 12, 2010, 05:29:28 PM »
That is true if you are swapping in a 16V.  If you are swapping in an 8V the disty spins clockwise.
Offline warbird
  • 110
« Reply #6 on: March 15, 2010, 04:09:56 PM »
Confusing but true!  ;)
