Tailgate Hinges
Tailgate Hinges
zukiguy
2
Tailgate Hinges
September 17, 2009, 09:29:59 AM »
The top tailgate hinge is tearing out of the body on my '88 samurai.
Does anyone know of a fix for this.
I know that it's the big tire causing it.
Drone637
8121
116
Evil Cow
Re: Tailgate Hinges
September 18, 2009, 01:05:39 PM »
Easiest fix would probably be to weld the hinge to the body. An alternative would be to remove the hinges and weld a bracing place to that section of the body and put the hinges back on.
zukiguy
2
Re: Tailgate Hinges
September 19, 2009, 12:24:42 PM »
Thanks Drone637
That makes sense to me. I had the body mounting plate brazed back in once. The body metal is so thin that it's hard to weld to. I Think that a larger reinforceing plate welded to the outside would be a good solution. I really want to carry that spare tire. Thae rocks around here are sharp.
Drone637
8121
116
Evil Cow
Re: Tailgate Hinges
Reply #3 on:
September 19, 2009, 03:03:17 PM »
You might want to look at just building a rear bumper with a built on tire mount instead. I moved mine into the back as I have a rear seat. Another club member has his built onto the roll cage, more of a baja style.
