Timing belt cover needed?
  • 1752 Views
« on: June 22, 2012, 09:04:34 PM »
So I'm still learning about the Sammi I bought, (first time owner)
It has over heating problems and was generally running rough.
I'm giving it a pretty good go over, re-packing the fan clutch, new thermostat, water pump and timing belt.
Then the usual oil change, plugs and wires... and anything else until I can get the bugs worked out.
I noticed however while researching the water pump/timing belt change, that the cover for my timing belt was missing. I'm showing my ignorance here, but is it needed? As in do I need to hold of on the swap till I can find one?
Offline WesP
  • 40
Re: Timing belt cover needed?
« Reply #1 on: June 22, 2012, 11:26:48 PM »
PetroWorks has them for $23.99.............
Offline kbeefy
  • 17
« Reply #2 on: June 23, 2012, 01:46:34 AM »
Theres a company called Dorman that makes them, I got one off ebay for under $20.
They're probably a good idea to have to keep stick and garbage out, but not mandatory.
Offline talonxracer
  • 1284
« Reply #3 on: June 23, 2012, 04:01:38 AM »
Being a interferrance fit engine you do not want anything to potentially get between the belt and gears as the timing will jump very easily and then you have a bunch of bent damaged internals. If it was a stationary engine used to run a generator then I would say the cover is optional, but on a street/offroad driven vehicle it should be considered very important.
« Reply #4 on: June 23, 2012, 09:35:16 AM »
Ummm - the engine in the picture has a pressed steel valve cover, so it'll be 8v and non-interference - still - a stick or rock in the belt when you're out in the trail is going to mean a long walk home, so I'd get a cover.
Offline talonxracer
  • 1284
« Reply #5 on: June 23, 2012, 10:21:13 AM »
darn, why was I thinking that when I know the difference?, old fart itus,,,,,
But still, the advice remains the same as Fordem pointed out.
Offline 86Sumo
  • 27
« Reply #6 on: June 24, 2012, 01:35:24 PM »
Plus it's alot easier to time the engine as the timing indicator is on the cover.
Bob
