Trackick 1in coil spacer and 31's
MAYHEM760
36
October 25, 2012, 07:22:39 PM »
Has anyone attempted this? Im running 235/75/15's right now stock with plenty of room to spare
Last Edit: October 25, 2012, 07:26:29 PM by MAYHEM760
chadstichter
162
5
98 4door home built coil yota swap 31s rear e-lock
Re: Trackick 1in coil spacer and 31's
October 25, 2012, 07:44:05 PM »
if you go to low rangeoffroad.com you can buy the budget lift for like 200 with shocks or 120 without shocks. it says like 29s but im running 31s if its a 2 door i would run 30s. with the 4 door 31s is just a little extra clearence for the extra lenth
98 4door home built coil yota swap 31s rear e-locker, 8000lb winch and synthetic rope
|...BEER TRUCK..........| ||'|";, ___.
|_..._..._______===|=||_|__|..., ]
l(|removethispart|@) (|removethispart|@) l(|removethispart|@) (|removethispart|@) l(|removethispart|@)
MAYHEM760
36
October 25, 2012, 07:52:32 PM »
I gave the bumpers a trim. I have 15X7 rims. Im thinking with a 1 inch spacer in the front the 31's should fit
MAYHEM760
36
Reply #3 on:
October 25, 2012, 08:21:06 PM »
Eh..30x9.5x15's seems more realistic.
beagle..t
1239
16
Reply #4 on:
October 25, 2012, 08:22:45 PM »
talk to jeff on here or mudchild im sure one of them can make you a 1 inch spacer
V6 swap auto ,2 dr ,2" BL,2" jeffs kit 512 gears warn hubs and 30/9.5/15 BFG AT
SIDEKICK65
176
Reply #5 on:
October 25, 2012, 08:29:15 PM »
Why dont you put 4 door coil's on your 2 door? it will give ya i think about 1 1/2 of lift.
MAYHEM760
36
Reply #6 on:
October 25, 2012, 09:05:21 PM »
I have 1in spacers already. The front is an inch shorter than the. rear. Really just looking to level it out.
jeff1997
1228
27
Suzuki: A Jeep thing only cheaper!!!!
Reply #7 on:
October 26, 2012, 05:14:54 AM »
Put 1.5" spacers in front, that will level it out. What do you have in the rear?
2" coil spacers- I make and sell 1.5" and 2" on e-bay. Look under seller: hoepkers
3" Masterkit1 body lift
Custom strut spacers
MAYHEM760
36
Reply #8 on:
October 26, 2012, 07:57:07 AM »
The rear is stock. Wouldn't a 1 inch spacer actually lift the front just over an inch? 1.5 spacer would lift the front much higher than the rear I would think.
jeff1997
1228
27
Reply #9 on:
October 27, 2012, 09:55:00 AM »
So you have no spacers in now? I am a little confused. Yes if the rear is stock a 1" spacer in front should level it out, maybe even raise it a little too much. I thought you had 1" spacers all around.
MAYHEM760
36
Reply #10 on:
October 27, 2012, 10:04:15 AM »
I have 1 inch spacers for the front, Just h of avent installed them yet. I have another set of 1inch spacers to trim down for the rear if the front ends up too high. Ill post pics when I install the front spacers.
