Timing question
  • 7 Replies
  • 2355 Views
Offline Zuki-Girl
  • 128
Timing question
« on: September 11, 2010, 05:51:21 AM »
the Sidekick is a 95 4dr 5spd 2 wheel drive. the engine is out of a 94 unknown model. Do i use the timing info under the hood(5btdc) or use the 94's timing? ECM is the 95s.
Re: Timing question
« Reply #1 on: September 12, 2010, 12:19:14 AM »
You will use the timing from the 95.
I have a 96 and run mine a few degrees in advance of what the timing info under the hood recommends (5 degrees).  Otherwise the engine tends to have a bit of a flat spot when accelerating between 2K and 3K on the RPM range.  I believe Wildgoody actually runs his between 10-12 degree advanced, but I don't know if that is with the diagnostic bit set or just when the vehicle is at idle.
Re: Timing question
« Reply #2 on: September 12, 2010, 08:19:37 AM »
That 10* was pre turbo, since then it has been timed by ear to reduce the pinging
Re: Timing question
« Reply #3 on: September 12, 2010, 12:59:54 PM »
Was that at idle or when you jumpered the computer into diagnostic mode?
Re: Timing question
« Reply #4 on: September 12, 2010, 01:00:46 PM »
Depending on the quality (octane) of the fuel available and what you're willing to pay for, you can run as much as 20* advanced - although I would approach it the way wild has, advance it until it just starts to ping and then back it off until it just stops.  There is a corresponding increase in performance and throttle response as you increase the advance.
Re: Timing question
« Reply #5 on: September 12, 2010, 04:46:07 PM »
That was without a jumper
Re: Timing question
« Reply #6 on: September 13, 2010, 01:22:26 AM »
Ok, so probably about a 2 degree advance over stock.  Thanks!
fordem:  Yea, but I don't trust my ears enough to do the timing that way. :P
Re: Timing question
« Reply #7 on: September 13, 2010, 07:46:17 AM »
If you don't trust your ears, the jumper it (which disables the ECU advance), set it to the FSM figures, and then remove the jumper.
