Torque specifications for 2.0L rod and main bearings
  • 1 Replies
  • 10724 Views
Offline rickdog
  • 14
  • Better living through recycling!
« on: August 01, 2009, 10:53:13 AM »
I have a 2001 Chevy Tracker 2.0L grocery-getter that needs to have the engine bearings replaced. What are the torque tightening specifications for the connecting rod bearings, and the main bearings? Anything else I need to know? This has beeen a great car!
Thanks,
Rick
'82 BMW RS100, 1973 Norton 750, 1968 BSA A 65, '91 Justy GL 4WD, '97 Legacy Wagon, 2001 Tracker, '88 Sammi yard goat
Re: Torque specifications for 2.0L rod and main bearings
« Reply #1 on: August 02, 2009, 07:45:13 AM »
The J20A does not have individual main bearing caps, but an upper and lower block arrangement - torque on the bolts is 60nM (43.5lbft) on the 10mm diameter bolts and 27nM (19.5lbft) on the 8mm diameter bolts - start at the center main and work your way outwards.
Rod bolts are 45nM (33lbft).
