O-2 sensor
  • 23 Replies
  • 6874 Views
Offline oak_raid
  • 193
Re: O-2 sensor
« Reply #15 on: June 22, 2010, 01:54:48 PM »
so... did sommore research and found that carb'd samurais have a High Altitude Controller (HAC) its supposed to be switched one way if you are below 4K feet in elevation and switched the other if you are above.  only problem is the chilton book i have is a POS, go figure and doesnt really do a great job of explaining if its good or bad.  i think this is it tho, correct me if im wrong.
Yes, that is the High Altitude Compensator.
The FSM should give you more info on that part than the Chilton or Haynes manuals.
Offline jow003
  • 403
Re: O-2 sensor
« Reply #16 on: June 22, 2010, 04:48:39 PM »
you got one you'd like to sell ???
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: O-2 sensor
« Reply #17 on: June 22, 2010, 09:15:48 PM »
Carb's don't use an 02 sensor
Umm, all samurais had an O2 sensor.
Umm, that's not 100% correct - maybe all US Samurais have an O2 sensor, but out where I am, Samurais generally don't have O2 sensors.  As a matter of fact, I also have a Grand Vitara with no O2 sensor(s), and yes it is fuel injected.
Re: O-2 sensor
« Reply #18 on: June 23, 2010, 12:31:11 PM »
Yes, I was referring to US samurais.
Offline jow003
  • 403
Re: O-2 sensor
« Reply #19 on: June 23, 2010, 12:41:30 PM »
does anyone know how to change the HAC or check the 02 sensor to see if its good?
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: O-2 sensor
« Reply #20 on: June 23, 2010, 01:03:16 PM »
HAC....unplug it and plug a new one in.
O2 sensor....I believe the FSM has the checking procedure in it.
Offline jow003
  • 403
Re: O-2 sensor
« Reply #21 on: June 24, 2010, 06:52:22 AM »
next question how does the HAC come apart?  i dont wanna break it and i dont know if it unscrews or just pulls out (the top from the bottom)
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: O-2 sensor
« Reply #22 on: June 24, 2010, 07:05:12 AM »
Unbolt it from the firewall, unplug the pigtail from the harness.  You don't take the HAC apart.  Don't make it harder than it is. ;)
Offline jow003
  • 403
Re: O-2 sensor
« Reply #23 on: June 24, 2010, 07:18:25 AM »
ooookkkkk. haha i was thinkin i kept some part of the housing but replaced somthing inside or ... i dunno
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
