TRACKER REAR CONTROL ARM BUSHINGS
  • 13 Replies
  • 7094 Views
Offline gearjam
  • 97
  • RC 2010
« on: June 03, 2012, 04:10:11 PM »
Anyone know where you can get these bushings at? Anytime you try to take a bolt out it is always frozen in the bushing. Conplete arms are $87.00  was hoping for something cheaper.
Offline talonxracer
  • 1284
Re: TRACKER REAR CONTROL ARM BUSHINGS
« Reply #1 on: June 03, 2012, 04:21:20 PM »
Offline z0mb1emutha
  • 38
« Reply #2 on: June 04, 2012, 02:03:15 PM »
I can get you the bushings $20 ea.
Offline talonxracer
  • 1284
« Reply #3 on: June 05, 2012, 04:22:00 AM »
20$ here http://www.carpartswholesale.com/v5/details/Suzuki/Sidekick/Beck_Arnley/Control_Arm_Bushing/1998/JX/4_Cyl_1-dot-6L/BEC1016287.html/?location=Front-comma-_Lower&sc=Product+Listing+Page:4
You can also pop out the stockie inserts and use urethane inserts, you will need to piece together the components from individual ES components.
« Last Edit: June 05, 2012, 04:26:00 AM by talonxracer »
Offline gearjam
  • 97
  • RC 2010
« Reply #4 on: June 05, 2012, 06:27:16 PM »
Those are for the front arms. I need them for the rear arms.
Offline talonxracer
  • 1284
  • 4327
« Reply #6 on: June 06, 2012, 11:59:12 AM »
What exactly are we talking about here?  The upper rear control arm bushings?  RockAuto shows them at $9.73.
Offline talonxracer
  • 1284
« Reply #7 on: June 06, 2012, 05:45:56 PM »
I assumed because he was saying rear arms(plural) he meant the rear lower arms(links)
  • 4327
« Reply #8 on: June 07, 2012, 09:55:46 AM »
That was originally my assumption two, but when I went to Rockauto, I realised that there's only one rear control arm, and two training links - hence the question - what exactly is it he needs?  I did notice that Rockauto had the complete rear arm for roughly the same price he mentioned.
Offline gearjam
  • 97
  • RC 2010
« Reply #9 on: June 07, 2012, 04:09:36 PM »
I am looking for what some of you are discribing as the rear trailing arm bushings. Now what many seem to think are being discribed as the rear bushing is actually for the rear of the front controll arm. The bushings on the front control are different sizes frt to rear. If some can tell me what poly bushings would fit  the rear lower trailing arms I would be happy to use them. They are not the same size as the Calmini trailing arm bushings.
Offline talonxracer
  • 1284
« Reply #10 on: June 07, 2012, 05:16:33 PM »
  • 4327
« Reply #11 on: June 07, 2012, 08:06:10 PM »
I don't know that I would use poly in the rear links - you need to have some flex in those bushes.
Poly is fine when the movement is in a single plane (like the front control arm bushes), the rear links on the other hand, move in a single plane only if both wheels move together - if one wheel moves more than the other (as is normal) the rear link bushes will rotate around the center bolt and also twist.  Poly, because of it's nature, will resist this twist and limit flex.
Offline talonxracer
  • 1284
« Reply #12 on: June 08, 2012, 06:18:16 AM »
Going with normal poly inserts should be fine for the chassis end of the trailing arm, you dont want much flex at this location(or the least amount possible) the axle end requires the flex joint. They do have poly inserts that allow for some flex as they have a cone shaped ends just like the stock rubber inserts.
With the AE4.5" lift kit they use standard poly inserts on the chassis end and large Creeper joints on the axle end, plenty of flex.
« Last Edit: June 08, 2012, 06:27:04 AM by talonxracer »
Offline gearjam
  • 97
  • RC 2010
« Reply #13 on: June 08, 2012, 04:12:11 PM »
THX those are what I want!
