Tranny Output Seal Keeps Leaking
weldboy
91
2
I'm only here for the carnival atmosphere !!!
October 02, 2010, 08:58:45 PM »
I've replaced the output seal 3 times and it keeps leaking. I first got a Timken seal from Napa, then 2 National seals from Rock Auto. The drive shaft is good and smooth no nicks or grooves in it, oiled it good and it slides right in. Maybe get a Suzuki OEM seal and try? Thankfully it's not hard to change out. Any ideas
wildgoody
8134
67
Re: Tranny Output Seal Keeps Leaking
October 02, 2010, 10:23:34 PM »
What trans? My auto always leaked, also if you are lifted the slip yoke
might be oscillating and wearing out, or just allowing oil to leak, also
is the oil level (man trans) over filled?
weldboy
91
2
October 02, 2010, 10:45:25 PM »
Sorry manual trans. not lifted. I just changed the oil in trans. after 3 rd. seal thought that should do it. Filled it till it was at the bottom of fill hole.
Last Edit: October 02, 2010, 10:48:37 PM by weldboy
wildgoody
8134
67
Reply #3 on:
October 02, 2010, 10:49:26 PM »
Lifted truck too? How about the oil level?
