Transfer Case Swap
  • 1713 Views
Transfer Case Swap
« on: April 02, 2012, 07:41:39 PM »
Will a 97 sidekick transfer case work in a 88 Sammi?  Thinking positively......If so what do I need to swap to make it work?
Offline SIDEKICK65
  • 176
Re: Transfer Case Swap
« Reply #1 on: April 04, 2012, 01:31:50 AM »
No
« Reply #2 on: April 10, 2012, 11:42:15 AM »
What Sidekick65 said.  :)
The sidekick transfer case doesn't have a high-range reduction like the Sammy ones does, if you want to run dual T-Cases you need a Kicker3 style setup.  Then use the Tracker 5-speed as well as a 1.6l.  It's a bit of work but pretty cool once you get it setup.
Offline fleX90
  • 11
« Reply #3 on: April 11, 2012, 05:05:33 PM »
Ive heard that OTT are no longer producing anything. correct me if im wrong
