manual ecm in an automatic?
  • 7 Replies
  • 4352 Views
Offline mypocketsrfull
  • 89
« on: January 07, 2011, 03:00:26 PM »
i think the answer is no, but i will leave it to the pro's.
can the ecm for a '92 geo tracker MANUAL be put into a '93 geo tracker AUTOMATIC without issue?  what would the issues be? thank you very much
Offline fuzzy1
  • 350
Re: manual ecm in an automatic?
« Reply #1 on: January 07, 2011, 03:43:43 PM »
Afaik, you are right; no... but...
Afaik, the manual/auto Ecm difference in those years is only that the auto Ecm has the TCC circuit.
You could put a switch & manually lock/unlock the TCC with it. Might be a pita for road driving.
I've read of guys doing that so they can lock the TCC on hill descents for better engine braking.
I think it was ebewley who mentioned it here before.
Hey Eric, what's it take to do this?
I'm curious too, I'd like to do it for road travel. I find some uphills I want to unlock the TCC but not have the pedal on the floor. If I let off it locks & I lose momentum. Sorry sounds sorta off topic. Maybe I'll start a post on it. (Mine's OBDII & the TCC circuit is different too.)
« Last Edit: January 07, 2011, 04:11:06 PM by fuzzy1 »
Non Illegitimi Conterat
Offline redidbull
  • 28
  • I love YaBB 1G - SP1!
« Reply #2 on: January 07, 2011, 03:51:49 PM »
I have fixed a bunch of ECMs and I believe the manuals are missing at least 1 transistor and related components. Jim
« Reply #3 on: January 08, 2011, 07:32:58 AM »
MT ECUs have different software so its not just a case of fitting any missing components.
Offline fuzzy1
  • 350
« Reply #4 on: January 08, 2011, 04:36:37 PM »
There you have it mypocketsrfull, & from two guys who know ECMs way better than me!
Thanks for the info redidbull & Rhinoman. :)
  • 89
« Reply #5 on: January 09, 2011, 10:39:45 PM »
thank you very much guys, that is kind of what i had thought, but it is definitely better to KNOW for sure. my next question is what other years for automatic trackers will work in a '93 auto? or are they all pretty much the same? i know ultimately its not the best idea to use an ecm from a junkyard, however new ones are too expensive, and i am still not 100% sure it is the ecm that is my problem (though pretty sure because we have had all kinds of wierd electrical problems and when i put the ecm from the manual in it started up even though it wouldnt start before that) thanks again guys
Offline fuzzy1
  • 350
« Reply #6 on: January 10, 2011, 09:17:51 AM »
Maybe it needs new capacitors? Pretty common problem in that era. FYI, redibull is pretty well known among the people who can repair them. I don't know him personally, just from reading on other sites, but maybe shoot him a PM & ask. G/l with it.
Fuzz
« Reply #7 on: January 11, 2011, 06:35:43 PM »
Actually, the manual ECM can be ran in your auto tracker.  But, it will run kinda funny and I recall that the TCC won't lock up.  But for testing purposes, you could do it....I wouldn't recommend running in long term though.
