Weber carb ???
  • 2305 Views
Offline 10mm shooter
Weber carb ???
« on: August 27, 2010, 01:04:11 PM »
I am looking at a Weber 32/36 carb for my 87 Sammy. My question is which choke setup (E, manual, or H2O) should I go with?
I have spent most of my money on women and beer - the rest... I just wasted!
Offline ft6crt
  • 10
    • The Abyss
Re: Weber carb ???
« Reply #1 on: August 29, 2010, 04:22:04 PM »
I went with the water choke and I'm not happy with it. Had (still have) issues with it sticking. I'll probably get a manual choke conversion for it. Other than that, it was fine.
H2O choke - Easiest installation
Electric - you need to re-plumb the water connections and run a wire to the choke.
Manual - you still have to re-route the plumbing and then install the choke cable.
Oh - the carb kit comes with a bunch of plugs for the vacuum ports - I still had to go find some others..
Cheers
Mike
  • 6594
  • 68
Re: Weber carb ???
« Reply #2 on: August 30, 2010, 07:47:54 AM »
If you're going to go with a Weber conversion definitely get the electric choke. It's an easy install and works real well. Make sure you get the 'off-road' model Weber. What they've done now is re-route the float bowl so that it vents into the charcoal canister now and so the hi angle wheeling doesn't effect it as much as it use to. Also get a fuel regulator and set it at 1.5lbs
Good luck, Eric
Offline Zuki-Girl
  • 128
Re: Weber carb ???
« Reply #3 on: September 11, 2010, 05:48:03 AM »
I bought a box of Samurai parts off Ebay for 150.00 and was surprised what I found in it. 2 8v tbi complete. So now I have tbi plus a complete extra one and the new weber on old manifold in my shed. Only thing extra I had to get was the harnes made up. Runs better than it ever did with the carb on it,and gets 27mpg now.
