What gears do I have?
  • 11 Replies
  • 3609 Views
Offline my88samurai
  • 43
« on: July 12, 2011, 04:02:46 AM »
Does anyone know what an 88.5 samurai came with for front and rear axle gears? It's a 5-spd. Thanks guys
Re: What gears do I have?
« Reply #1 on: July 12, 2011, 07:34:11 AM »
All 86-95 samurais come with 3.727 (most people call them 3.73) gears.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #2 on: July 12, 2011, 12:03:33 PM »
Is there a  standard transfer case gear ratio as well? Or is there a tag / identifing marks to tell?
« Reply #3 on: July 12, 2011, 12:06:04 PM »
Samurai tcases have a 1.409 high ratio and a 2.268 low ratio.
Offline my88samurai
  • 43
« Reply #4 on: July 12, 2011, 02:39:57 PM »
Ok cool i had thought about puting 4.10's in it but that might be just tooo low for the street more the highway. Anyone have 4.10's in theirs?
Offline Jluck
  • 1389
  • 40
« Reply #5 on: July 12, 2011, 09:56:59 PM »
3.73's to 4.10's is hardly any difference at all. are your tires oversized? you might need way lower to see any useable gains.
Offline my88samurai
  • 43
« Reply #6 on: July 14, 2011, 04:11:37 AM »
I have 33's right now and it's pretty balless. I figured with lower gears and taller tires it would help a little
Offline Jluck
  • 1389
  • 40
« Reply #7 on: July 14, 2011, 08:11:23 AM »
lower gears will definitely help you. especially with 33's. you just need way more of a change than one gear set (3.73's-4.10's). I would be looking in 5.12's that will get your rig back to near stock performance.and you can find those thirds from sidekicks pretty readily. :)
Offline my88samurai
  • 43
« Reply #8 on: July 14, 2011, 08:13:40 PM »
Sidekicks had 5.12's factory? Whats my top speed gonna be you think?
Offline Jluck
  • 1389
  • 40
« Reply #9 on: July 14, 2011, 08:45:48 PM »
Yep, all 16v 4doors had them and maybe others. And I don't know about "top speed" maybe 60 ish. If that's the priority the higher gears might suit you better. I thought you were looking to restore lost power from the bigger tires.
Offline my996duc1
  • 222
« Reply #10 on: July 15, 2011, 01:02:28 AM »
gearing calculator here : http://www.grimmjeeper.com/gears.html
you can compare two different setups at the same time on here too.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Offline my88samurai
  • 43
« Reply #11 on: July 15, 2011, 04:07:53 AM »
Cool thanks. Top speed isn't a big deal. It's not exactly a highway mobile
