window regulator
  • 2256 Views
Offline 4x4kingx889
window regulator
« on: January 08, 2016, 05:53:40 PM »
I have a 98 tracker which I installed a brand new regulator in and for the life of me I cant balance it right no matter what I do the windows gos up crocked and you need to use both hands to guide it up...I removed all the rubber strips lubbed everything up nothing is rubbing it that I can see and the window still goes crocked half way up any one know what I can do to fix this?
Re: window regulator
« Reply #1 on: January 09, 2016, 02:07:50 PM »
Did you have to attach the regulator to the glass?  I haven't worked with this specific vehicle, but, f I recall correctly, having the regulator positioned incorrectly on the glass can cause problems similar to those you are describing - some fixtures allow you to slide the regulator along the bottom of the glass, if yours does, try moving it slightly in either direction.
Offline 4x4kingx889
« Reply #2 on: January 09, 2016, 06:52:14 PM »
yes I tried moving it all kinds of ways and still cant get it to work right
Offline Big O
  • 9
« Reply #3 on: January 21, 2016, 09:00:31 AM »
pull the front  guide out then try..
Offline 4x4kingx889
« Reply #4 on: January 24, 2016, 03:47:47 PM »
what do you mean by front guide?
