Stuck Dif Cover
Stuck Dif Cover
timpvjr
4
ZUKIWORLD Online!
Stuck Dif Cover
January 04, 2016, 03:04:07 PM »
Hello!
I'm trying to install a Spartan locker on my front differential. I have removed the axles, and all the bolts, but I cant seem to get it apart. Any ideas?
Thanks!
fordem
4334
170
Re: Stuck Dif Cover
January 04, 2016, 03:51:33 PM »
What are you trying to remove - the "cover" or the third member - and what vehicle are we discussing?
timpvjr
4
ZUKIWORLD Online!
Re: Stuck Dif Cover
January 04, 2016, 04:06:53 PM »
Its an 86 Samurai. The front of the dif that houses the pinion.
fordem
4334
170
Re: Stuck Dif Cover
Reply #3 on:
January 04, 2016, 05:23:45 PM »
Presumably you already have the drive shaft removed, put a jack under the nose and jack it up some, it's most likely the sealant that's holding it.
timpvjr
4
ZUKIWORLD Online!
Re: Stuck Dif Cover
Reply #4 on:
January 04, 2016, 05:24:59 PM »
That's a good idea. Thanks!
