1.6l 8v 5 speed swap to 1.8l?
  • 3232 Views
Offline Sidekickguy_1
« on: January 07, 2016, 06:57:17 PM »
Hi. I have a 96 sidekick jlx sport with the 1.8l auto. I was wondering if you can swap a 94 tracker 1.6l 8v 5 speed tranny into it? Thanks in advance.
96 sidekick jlx sport 1.8L
Re: 1.6l 8v 5 speed swap to 1.8l?
« Reply #1 on: January 08, 2016, 05:55:40 AM »
I believe you can, but from what I recall, it is not a direct bolt-up swap - I think there is a difference in the clutch/input shaft area.
Edit -
Sorry - I just realized that your 1.8 is an automatic, my earlier reply was considering a 1.8, 5 speed to a 1.6, 5 speed - an auto to manual swap is a lot more involved - in addition to the mechanical aspects of the swap, you'll have to consider the electronics.
« Last Edit: January 08, 2016, 05:59:05 AM by fordem »
« Reply #2 on: January 08, 2016, 07:26:41 PM »
The body of the 5 speeds in the 1.8 sidekick sports and the 1.6 regular trackicks are the same. The bellhousings are different, because the 1.8 uses a hydraulic clutch and the 1.6 uses a cable actuated clutch. The flywheels are different between 1.8 and 1.6 trackicks.
As far as swapping from a 1.8 auto to a 1.6 5 speed. I supposed it could be done. There aren't any electronics that control the 5 speed, like there is with the auto tranny.
The tranny lengths are different between the 1.8 4 speed auto and the manual 5 speed tranny. So you will need driveshafts to match the tranny (5 speed auto) and wheelbase (2 door or 4 door) combination.
The transfer case shifter will also have a slightly different bend in it. You can either get one from a transfer case that came from a 4 speed auto 4 door, or you can probably bend the one you have to work.
