1988 Suzuki Samurai 1.3 4X4 No Spark
  • 1 Replies
  • 2122 Views
Offline SybilsWays
« on: February 17, 2020, 01:56:05 PM »
We installed a used engine that and after install it started but the water mixed with the oil. I took the head off and had it checked along with a valve job. Put it back together and now no spark.
The distributor rotor is turning, we have power to the coil and no spark.
What are your thoughts?
Re: 1988 Suzuki Samurai 1.3 4X4 No Spark
« Reply #1 on: February 17, 2020, 05:40:15 PM »
Check for spark at the coil - if you're not getting a spark there you most likely have an electrical issue, if you have a spark there but not at the plugs, the distributor is probably installed incorrectly.
