yj spring swap ?'s
  • 2737 Views
yj spring swap ?'s
« on: March 10, 2011, 05:35:17 PM »
Found a stock set of yj springs off an 88 for 75 bux...     What will i need to have to swap em, and what will i run into as far as needing to buy or fab up....  will it lift at all?   thanx guys
Offline Hubbachubba
  • 19
Re: yj spring swap ?'s
« Reply #1 on: March 10, 2011, 07:04:59 PM »
You will soon realize that the yj springs are the cheapest thing to buy. I have them on my 88 samurai, they work really great, i have the yj mounting kit from Sky, i have spring over, i have had to buy longer shocks, i made my own front shock hoops to get all the travel i could get. longer front drive shaft, i have an extented slip yoke in the rear. longer brake lines. I have the mercedes steering arms with a modified draglink. I have 33's on mine with locrite front and rear, 6.5:1 transfer case with solid mounts and reinforced brackets. :laugh:
Offline my996duc1
  • 222
« Reply #2 on: March 12, 2011, 09:09:51 AM »
I went with the Trail Tough missing link setup, check it out here :
http://www.trailtough.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=36&category_id=7&option=com_virtuemart&Itemid=53
Detailed installation instructions here :
http://www.zukiworld.com/month_050104/feature_trailtough_yjlift_install.htm
Depending on how you are sitting right now but if your Sami is stock it will lift it, give it more flex, and probably ride smoother.
I also have ALOT of other parts on the Sami but the pics can give yo uan idea of how mine sits and stretches.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Offline Jluck
  • 1389
  • 40
« Reply #3 on: March 12, 2011, 09:23:51 AM »
both good lookin Sammy guys
