100 hp 1.3 motor samurai salvage?
  • 7448 Views
Offline MAX H
« on: July 05, 2012, 10:57:20 AM »
Has anyone used the 100 hp motor from rod at samurai salvage? I am looking at getting one set up with the weber and header , cam ect..
I cant find where anyone has reveiwed them. Please send me your comments if you have used this motor
Thank you
MAX H
New Member first post
Re: 100 hp 1.3 motor samurai salvage?
« Reply #1 on: July 06, 2012, 12:08:52 PM »
While I have not bought a built engine from anyone, I would recommend buying from Zack at zukiengines.com.  From what I have read/heard, his attention to detail and workmanship are second to none.
I have not heard of anyone buying a built engine from samurai salvage...that could be good or bad, I guess.
Offline MAX H
« Reply #2 on: July 09, 2012, 08:11:32 AM »
Thanks for the input do you think 100 hp is reasonable?  They use higher compresion pistons , cam ,weber & headers.
Does the guy at zukiengines have a high perf 1,3 motor?
Thank you for your comments
Max H
« Reply #3 on: July 09, 2012, 08:32:05 AM »
Well - since you ask - I don't think 100hp from the 8v 1.3 is that easy to achieve - it's rated at around 65 hp stock, there is a twin cam 16V version that does deliver 100hp, so it is possible, but on the 8V, that extra power will mean extensive top end modifications, and you can expect the power at the top of the rpm band, is that what you really need off road?
« Reply #4 on: July 10, 2012, 08:08:09 PM »
Well i just rebuilt my 1.3 with 9.5.0flate top pistons and had my machine shop custom ground midrage cam with Honda vavle springs. With the webber and header this thing rips on the freeway.You can actually feel it pull or come on the cam. My jeep buddies cant beleave on how good it runs.Note if you are running t-case gears dont put the low range cam in it you will not go faster than 55mph on the freeway.
« Reply #5 on: July 10, 2012, 10:29:53 PM »
That pretty much sums up my response too.
  • 6573
  • 66
« Reply #6 on: July 11, 2012, 03:19:42 PM »
X3
