16v stock injector swap to 330cc +
  • 17 Replies
  • 7194 Views
Offline zuki1018
  • 397
« on: March 02, 2012, 02:11:18 PM »
Looking to get larger injectors.  Not clear on what style the 1.6 16v trackers have. Denso?  I want something in the 330cc to 360cc range... possibly off a different vehicle. TIA
« Last Edit: March 02, 2012, 02:14:11 PM by zuki1018 »
Re: 16v stock injector swap to 330cc +
« Reply #1 on: March 02, 2012, 02:15:07 PM »
Look at Subaru injectors.
Offline zuki1018
  • 397
« Reply #2 on: March 02, 2012, 02:18:52 PM »
Subaru on ebay
they dont look the same as whats online as a stock replacement for the trackers?
Offline zuki1018
  • 397
« Reply #3 on: March 02, 2012, 02:22:14 PM »
These appear the same... listed as a 360cc denso
« Reply #4 on: March 02, 2012, 05:43:31 PM »
Why so big? Are you running that lean? Can the MS be set up to alter the duration of the injector on time also?
Offline zuki1018
  • 397
« Reply #5 on: March 04, 2012, 02:55:21 PM »
Based on the online injector calculators, 330cc should support the rough HP numbers Im looking ahead to.  I have seen some forum posts that say the stock tracker has 175cc and others that say they are 250cc.  Either way I am just planning for down the road.
MS lets you adjust just about everything! It calculates injector timing for you (Required Fuel Calc.) or you can adjust I suppose.
« Reply #6 on: March 04, 2012, 05:05:07 PM »
That MS is certainly tuneable, nice to be able to just plug in the laptop and dial it in I bet. Stock injectors are 175. With a 330 you should have all the room you need to find the sweet spot, you'll probably have to up the pressure in the rail though, ya think?
Offline zuki1018
  • 397
« Reply #7 on: March 04, 2012, 05:16:21 PM »
Yeah its really great. My awesome (understanding & interested) better-half does the tuning while I am driving. The biggest problem is not having a way to suck the stock spark maps from the ECM.  My curves are just a calculated guess.
The stock FPR must be on a 1:1 ratio.  We slowly made our way up to 12psi the other night.  I was still getting great air/fuel mixture.  I suppose the injector duty cycles could have been above nominal range as well.  We only did short bursts/runs over about an hour or so. When I look up the 175cc calculations it doesn't show it supports that much boost.
I am still hoping someone chimes in on what brand/model injectors they are ...or are compatible with.  I am going to leave the turbo at the stock wastegate setting until i find injectors.
Right on about the need to restrict the oil to the turbo also :)  ...I looked like mosquito control after boosting heh!
« Reply #8 on: March 05, 2012, 03:02:21 PM »
Stock FPR is 1:1
The injector number should be marked on it, from memory i think they are Nikki INP470.
I just pulled the binary from a 96 US AT today, I haven't looked for the tables yet, I suspect they are similar to the OBD1 models.
http://www.rhinopower.org/ECUs/71EC1/docs/EE93.bin
« Reply #9 on: March 05, 2012, 03:13:55 PM »
I don't remember the part numbers offhand, but I'm running 210 cc injectors out of a V6 Nissan Pathfinder. I also contacted an injector supplier from one of the ebay sellers and he was quite helpful in cross referencing  the plug style and sizes ( ppm, etc) so the ones he sent me fit like stockm right down to the electrical connection.
Offline zuki1018
  • 397
« Reply #10 on: March 05, 2012, 03:32:37 PM »
Stock FPR is 1:1
Fantastic!  Is that BIN file correct its only 64kb in size?
« Reply #11 on: March 06, 2012, 04:27:05 AM »
64k is correct, 0000h to FFFFh.
Offline zuki1018
  • 397
« Reply #12 on: March 06, 2012, 07:58:09 AM »
Man ...I may need to do some reading.  I still haven't figured out how to write that BIN file to a virtual drive let alone figure out what 0000h to FFFFh means ha.
I suppose even if i get this file figured out, the factory ECU's do a lot of math from many sensors to calculate a spark curve.  I would have to reverse engineer it to get it into a usable Megasquirt input (12x12 RPM and MAP based table).
PS. this table is not accurate for the 16v... just an example of inputs
Offline zuki1018
  • 397
« Reply #13 on: March 10, 2012, 07:21:57 AM »
On your turbo setup?  How much boost are you running with those injectors... and do you have an adjustable FPR?
« Reply #14 on: March 10, 2012, 01:18:49 PM »
I would expect the primary spark table to be 16x16 with a non-linear RPM axis, thats how the 8V ECUs of the same period are setup. There are fewer parameters for the spark than for the fuel but there are a lot of back-up/default values to keep things running in the event of a sensor failure. The 16V Track/Kick ECU is pretty sophisticated but not on a par with the Baleno/Esteem ECUs which use a 16-bit dual core processor.
