1990 sammy ecm problem?
  • 11 Replies
  • 3407 Views
« on: March 12, 2010, 05:36:31 PM »
I have a 1990 sammy i recently had the ecm rebuilt by a guy in minnasota i got it back and for some reason when i turn the key on it is dumping a bunch of fuel into the throttlle body i was told its only suppose to spray when the igntion is turn too crank the engine is this right? Or does someone know whats up with it?
  • 6577
  • 66
Re: 1990 sammy ecm problem?
« Reply #1 on: March 12, 2010, 05:53:28 PM »
The fuel pump relay on that vehicle should come on for 3 to 5 seconds when you turn the key to the run position. It should then turn off. It'll turn back on during the engine crank and will stay on once the engine is running.
« Reply #2 on: March 12, 2010, 06:25:47 PM »
So are u telling me it could be a fuel pump relay? Sorry im new at this just want to go play
« Reply #3 on: March 13, 2010, 01:23:32 AM »
no, sounds like the ECM needs to go back to get fixed right
« Reply #4 on: March 13, 2010, 03:47:20 PM »
Ive check the ohm readings on the fuel pump relay and main relay too and they both read what the book says they should read suthin is tellin the fuel injector too dump lots of fuel before ignition is in crank mode there for the plugs are flooded with fuel im thinkin its a ecm problem
« Reply #5 on: March 14, 2010, 09:48:24 AM »
Just changed the fuel pump relay and no luck sammy still runs ruff and smokes as if its flooded still gettin to much fuel
« Reply #6 on: March 14, 2010, 03:26:25 PM »
I got it too run long enough too get the code off of it the check engine light blinked twice with a 3 sec pause then it blinked 3 times which according too my book that is a air temperture sensor i took it out and measured the ohms on it and i couldnt get it too read anything no matter if the water was cold or hot so im guessing maybe that could be it dont know? What do the sammy pro's think?
« Reply #7 on: March 15, 2010, 12:43:44 AM »
I guess it could be getting a freezing cold signal and injecting
a cold start fuel amount, did you check the MAP vacuum line,
if it's off it will run like that too
« Reply #8 on: March 15, 2010, 03:48:08 AM »
NO HAVENT CHECK THAT YET BUT I WILL THANKS
« Reply #9 on: March 16, 2010, 06:13:19 PM »
Problem fixed it was the o ring at the bottom of the fuel injector thanks too wildgoody or i would have never figured that out great guy thanks!
« Reply #10 on: March 21, 2010, 08:18:28 AM »
So the oring was not there (or not sealing) and allowing the fuel to be pumped straight into the throttle body by bypassing the fuel injector, right?
For future reference.....
The fuel pump relay just builds fuel pressure (by activating the fuel pump)....it doesn't control the firing or spraying of the injector (the ECM does that)....so the fuel pump relay would not cause the fuel injector to dump fuel into the throttle body (that is, assuming the oring is sealing off the fuel like it is supposed to).
« Reply #11 on: March 21, 2010, 11:16:03 AM »
Thanks for the advise
