2.0 head on 1.6 ????
  • 2732 Views
Offline sidekickyc
  • 137
« on: October 13, 2018, 09:48:22 PM »
Someone was talking about putting a 2.0 liter head on a 1.6 liter engine ~ can this be done or is he talking out of his hat ```
Thanks guys
Richard
« Last Edit: October 13, 2018, 09:51:37 PM by sidekickyc »
Offline sidekickyc
  • 137
Re: 2.0 head on 1.6 ????
« Reply #1 on: October 13, 2018, 09:53:42 PM »
Sorry don't know why the text is so far down on the OP```
Offline thebanjoman
  • 72
« Reply #2 on: October 14, 2018, 02:58:59 AM »
Not possible,  totally different motors.  2.0 is a DOHC  1.6 is a SOHC
« Reply #3 on: October 14, 2018, 08:30:22 AM »
Whilst you're correct in saying it won't fit, your reasoning is flawed - it has nothing to do with the number of camshafts - the reason it won't fit is the motors are two different families and the bore dimensions & spacings are different.  The 2.0 is a J series, the 1.6 is G series.
For what it's worth - you can swap the G13 DOHC head onto the G13 SOHC block (the G13 was the only G series motor offered with a DOHC head) - you may need to swap the rotating assembly depending on which version of the motor you're dealing with - as the DOHC is a 16 valve motor, and the SOHC was available with either 8 or 16 valves - you can also swap the heads between the G13, G15 & G16 engines - in fact, the 16v SOHC versions of these three motors all use the same part number.
You can also swap the heads (and the blocks) between the J18 & J20 motors, I believe the head will also fit the J23, but not the J24 - it should be noted here that there are variations amongst the later J series so whilst the heads will bolt up you may find that camshafts and cam sensors are different and so on.
« Last Edit: October 14, 2018, 08:33:21 AM by fordem »
