5 SPEED TRANSMISSION SENSOR Q'S
war_paint
9
July 18, 2011, 07:27:18 PM »
MY 88 SAMURAI TRANSMISSION SENSOR WIRES GOT CUT WITCH WIRES GO TO WHITCH SENSOR ??
CAN SOMEONE LOOK FOR ME AND POSSIBLY GIVE ME WIRE COLORS TO BOTH SENSORS (5TH GEAR & REVERSE)
88' SAMURAI (FULLY BUILT 1.3L W/ POWER STEERING ,35"TIRES , RUF SPRING OVER W/TOYOTA AXLES & MISSING LINK SHACKLES, .529 GEARS & 6.5:1 TRANSFER CASE)
fordem
4334
170
Re: 5 SPEED TRANSMISSION SENSOR Q'S
July 19, 2011, 05:53:27 AM »
Short them together and switch the ignition on - one pair will light the reverse lights - connect that to the reverse light switch, and the other to the 5th gear switch.
And FWIW - posting in upper case is considered yelling and rude.
ack
1659
34
Professional askhole
July 21, 2011, 05:50:37 PM »
Also, take a look at this:
http://www.acksfaq.com/diagram_color_86-88_sam.htm
Ack
Ack's FAQ
war_paint
9
Reply #3 on:
July 28, 2011, 09:13:19 AM »
thank you guys
i appreciate the help
