30mm Lift kit
  • 1 Replies
  • 1432 Views
Offline eyco
30mm Lift kit
« on: October 17, 2019, 03:10:23 AM »
Is it ok to install a 30mm spring spacers on the grand vitara? I mean only for the springs without the struts.
Re: 30mm Lift kit
« Reply #1 on: November 01, 2019, 09:55:35 AM »
That should be fine.  Remember that when you install it in the front you will get a taller lift due to the angles vs the rear.  The front usually sits lower anyway, so it levels things out nicely.
If you find your topping out your struts when coming off bumps you might want to install a 1" spacer lift on the front struts as well.
