GV Diff Swap
  • 2581 Views
Offline PEIZUK
GV Diff Swap
« on: November 18, 2016, 05:45:33 PM »
 OK, I am sure this is been discussed on here before. I have read online about the possibility of installing a steel front diff of a Grand Vitara into my 02, 2 door Vitara.
 Now of course if you just ask the guy at the auto salvage he will say no they do not interchange.  But we were able to confirm that I do have the same gear ratio. What is involved in putting the GV front diff into my little two door?
Re: GV Diff Swap
« Reply #1 on: November 19, 2016, 02:25:50 PM »
It depends on what year Grand Vitara - there are two different styles of third member mount - make sure you get the matching mount and it should be a bolt up affair.
Offline PEIZUK
Re: GV Diff Swap
« Reply #2 on: November 19, 2016, 04:01:05 PM »
Well, I'm looking at the 04/05 GV diff. My Vitara is an 02. Will it slide right in?
Re: GV Diff Swap
« Reply #3 on: November 20, 2016, 08:28:28 AM »
The third member mount will be different, so make sure you get the mount as well.
